POS Fuel Filter Rusted on too tight
Old Aug 21, 2008 | 09:03 PM
1989irocz1's Avatar
Car: 1989 Camaro Iroc Z28
Axle/Gears: Borg Warner 9-Bolt/ 2.77
I have a 1989 tpi camaro. My fuel lines and the fuel filter are "welded" together by rust. I used a lot of PB Blaster and went out and bought some flare wrenches to break it apart. I ended up with a partially stripped fuel line end. What should I do now, or should I be asking how much will the mechanic charge me to install it?
Old Aug 21, 2008 | 09:20 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: POS Fuel Filter Rusted on too tight
you could try a nice set of vice grips if its too stripped. just grip them on real tight and they shouldnt slip. also try beating an end of the wrench against the hex head of the screw part to try and knock the rust loose. also you do know that if you wait after you spray pb blaster a little while itll become looser not immediately.
Old Aug 21, 2008 | 09:23 PM
1989irocz1's Avatar
I waited an hour after spraying pb blaster, no luck. I'll probably buy some vise grips. It pisses me off that GM likes to put the filter where it can corrode easily.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
