changing to arp main studs???
Old Aug 22, 2008 | 10:38 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
I have a 383 lt1 that just broke its second main cap bolt. they look like stock ones to me i was told it had arp though. But i decided to order some studs to try and keep it from happending again. i was looking at the instructions on the studs and it says you have to have the block aligne honed with them installed.
I really dont have the time to pull the motor and break it down right now i was wondering if it is absolutely necessary to do this?
I just wanna get my car back up and running since its my dd.
Old Aug 22, 2008 | 10:49 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: changing to arp main studs???
You probably have a problem if you're breaking main cap bolts, and the problem is probably not the bolts.
Yes, you're supposed to have it honed with the new studs and the increased clamping force.
No, you don't have to, it will probably live without doing it. Mine has.
Old Aug 22, 2008 | 10:54 PM
gapimpin's Avatar
Engine: 383 LT1
did you tighten yours down to 80ft/lbs like arp says too or did you do a little less?
Old Aug 22, 2008 | 11:00 PM
Lo-tec's Avatar
Torqued to whatever ARP says. If it says 80 ft-lbs, do it.
Old Aug 22, 2008 | 11:24 PM
gapimpin's Avatar
Engine: 383 LT1
thanx for the quick response.
and im sure the problem with the main bolts is timing related. wich i will fix but since im gonna be in the bottom end anyways figured i would upgrade the mains.
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Aug 25, 2015 12:54 AM
LT1Formula
Aug 20, 2015 09:36 PM
