idle rpm
Old Aug 23, 2008 | 02:33 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
idle rpm
i have a 350 enigne in my 1984 camaro. when i start it up it idles at bout 500rpm and then it stalls out. whats the rpm level i should be running at? i think im to low. if i keep foot on gas it idles fine. thanks
Old Aug 23, 2008 | 02:47 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: idle rpm
umm try adjusting your idle adjust screw and brin the idle up to about 600-700 rpms or high enought that it doesnt die...no sense in keeping ure foot on it to keep it alive
Old Aug 23, 2008 | 10:58 PM
bigboy123's Avatar
Re: idle rpm
check your vaccum hose for any leaks, mine did the exact same thing, and my vaccum hose was leaking
Old Aug 24, 2008 | 01:05 AM
Engine: 355
Re: idle rpm
ya im gna adjust it a lil higher to idel better
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
