Intake bolts
Old Aug 26, 2008 | 05:10 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Intake bolts
So I pulled a bonehead move. I installed my new 350 into my Camaro over the weekend, and in the process I lost the two rearmost intake bolts on the drivers side. In a rush to get this thing fired up, I decided not to worry about it. So I fired it up and ran it for about 2 minutes and it started getting alot of white smoke from the tailpipes, which I assume is water leaking past the gaskets and into the cylinder. Haven't run it since and I have replaced the two missing bolts. I checked the oil and there was quite a bit of water in it. My question is, did the water come from the leaking intake, or do I have to worry about a possible head gasket problem?
Old Aug 26, 2008 | 05:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably the missing intake bolts. Don't run the engine until you've changed the oil and filter. See if the problem persists.
Old Aug 26, 2008 | 06:42 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: Intake bolts
Pressure test the cooling system while the oil drain plug is out, make sure the cooling system holds pressure and no more coolant/water runs out the oil pan. Water = Zero lubrication.
Old Aug 26, 2008 | 08:48 PM
84Z28406's Avatar
Re: Intake bolts
That's the plan, just wanted a second opinion.
I'd pressure test the coolant system but I don't have the equipment for that. Ill just run it and continually check the oil for water for the first few minutes of run time.
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
