Distributor Advance
Old Aug 27, 2008 | 06:46 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Distributor Advance
This is probably a dumb question, and I'm pretty sure I know the answer but I wanted to double check myself. I found an 84 Berlinetta at the local U-Pull and its had the engine swapped from a v6 to a V8 judging from the VIN. The distributor in it has a vacuum advance can on it as well as an HEI coil. Am I correct in thinking that the advance can't be computer controlled on this??? I need a vac advance non-computer-controlled HEI distributor for my V8 swap and I want to make sure this one will work before I go to the trouble of pulling it. I'm 99% sure on this, I just want to be 120% sure. Thanks.
Old Aug 27, 2008 | 06:50 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Distributor Advance
If it has vacuum advance it is not computer controlled.
Old Aug 27, 2008 | 06:59 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Thanx for the quick reply.
That's what I thought. I thought it was one way or the other, not both. For whatever reason my memory just quit on me there. Maybe 5 hours the u-pull in the sun was too much?? I dunno.
Thanx again.
MM2Robinson
Oct 1, 2017 09:16 AM
Zane Story
Oct 8, 2015 12:40 PM
Jorlain
Oct 8, 2015 01:57 AM
Camaro_383
Sep 11, 2015 11:28 PM
Jlanz55
Sep 6, 2015 03:05 PM
