combo cooler eng/trans heat transfer?
Old Aug 28, 2008 | 11:28 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i have a derale combo cooler for engine and trans oil. core measures 12x17. 6 pass for the engine oil and 4 pass for the transmission. right now i only have the transmission hooked up to it and my trans temp gauge never goes above 170 degrees in 100 degree weather and that is with a 2600 stall.
now i know that engine oil temp runs in the 250 degree and up area, so my question is, would there be a lot of heat transfer from the engine oil to the trans oil because of them being on the same unit, i don't want my trans temp to be warmed up to 250 degrees.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
FormulasOnly
Oct 2, 2015 05:52 PM
