Do lg4 heads have an exhaust crossover?
Old Aug 31, 2008 | 04:05 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Here is my situation. i am in the middle of a converting my 86 LG4 Z28 to TPI, and while re-drilling the four center bolt holes in the new TPI manifold i managed to put a hole in the exhaust crossover, the passage that feeds the EGR valve. my question is do my old LG4 heads have an exhaust port @ this location or not? if they do i will have to weld up the hole i created or i assume it will vent exhaust from the intake, if not i will just leave it as-is.
heres a photo to clarify, please dont bash my poor machining, it will be functional not pretty.
http://members.shaw.ca/downfamily/TPImistake.JPG
-Zander
Old Aug 31, 2008 | 04:35 PM
Guest
Guest
Posts: n/a
Re: Do lg4 heads have an exhaust crossover?
Yes they do.
Some gaskets have that area blocked or a blockoff plate, but I'd fix the manifold if it was me.
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hayesaw0210
Aug 23, 2015 11:15 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
drathaar907
Aug 6, 2015 04:20 PM
