Smog Pump
Car: 86 Z28
Axle/Gears: 3.42 posi
Smog Pump
So I had to take the ac belt off cause all the oil leaked out
So I thought I would see how it ran without the belt on the smog pump, It seemed fine didn't set off any codes. The only thing that happened was I just drove it about 1000 ft shut it off came back in 5 mins and started it and was looking at something and then was going to take off and noticed the check engine light then saw it had quit it fired right up and seemed to run fine after that.
What would cause that?
I don't see how it could possibly be the smog pump, but I will throw the belt back on.
