Code 22 Car won't run
Old Sep 4, 2008 | 02:09 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
First of all i have searched. That being said, My car has always had a problem with the idle. Kinda wanders a little. Codes 21 and 22 would come on once in awhile. I replaced the computer with a reman. unit a few years ago and replaced the TPS with a GP sorenso sensor. it never stopped the wandering idle. Now the other day my car won't start without giving it at least 50% throttle and then it runs really rough and i can smell what i believe to be gas.
And the code 22 came back. I tried to get readings on the TPS and i can't even get a constant voltage off the C wire. Someone please help. Thanks.
Old Sep 4, 2008 | 02:54 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Code 22 Car won't run
See my response to this in the TPI forum.
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
squiggy2
Aug 9, 2015 09:30 PM
