? about walbro255 pump installtion
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I bought this used so I dont have any instructions? I removed my oem fuel pump and noticed it had rubber couplings on both ends of the pump. My question is do you use these rubber couplings on the walbro pump? It seems like you dont need the one on the top of the walbro pump because there is already a rubber coupling built on to it. Also when I replace the fuel filter can I just pick up one from the hardware store or do I have to order on form walbro?
Car: 91 Trans Am
Re: ? about walbro255 pump installtion
I am trying to find a install kit to order but I cant find one anywhere. Can someone help me find a install kit for a walbro 255 fuel pump?
Car: 1989 Camaro
Engine: 383
Car: 91 Trans Am
It does by looking at the picture but I just wish I could by a install kit only since I already have the pump. I will just piece it together I guess.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
