ughhh is this another problem related to the fact that im using a quadrajunk??
Old Sep 5, 2008 | 02:00 PM
cashfella's Avatar
Car: 88 Camaro. 99 Grand am.
Transmission: t-5
Axle/Gears: 3.08
i have a stock 305 in my 85 z wit an electric fuel pump and a stock quadrajet. my car wont start but it constantly cranks over even after depressing the gass pedal a few times. i changed the distributor cap with a new coil and still the same problem. i tried starting it with starting fluid and it started right up.for about 10 seconds. a couple of techs are saying its probably the module inside the distributor? could that be my problem? i need to kno asap becuase my car is parked in front of some random persons house and i dont want them to tow it. thanks for the help
Old Sep 5, 2008 | 02:33 PM
5thFbody's Avatar
Car: 87 LT bird,82 Trans-am
Engine: 305,383
Transmission: auto
Axle/Gears: 10 bolt 2.73,323
Re: ughhh is this another problem related to the fact that im using a quadrajunk??
More than likely that is your problem. My Bird did it to me a few months back. They get hot and fail when it is the worst time.Do you smell gas at the carb or can you see it being squirted into the carb? Simple stuff first then go for electronics. Let me know if you need help.
Old Sep 6, 2008 | 12:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's a pretty solid indication it has nothing to do with the ignition. Starting fluid still needs to be ignited.
Why does it have an electric fuel pump on it? Are you saying a factory electric pump, or something that has been put on? Do you have fuel pressure? With the air cleaner off, holding the choke open, and opening the throttle do you see a squirt of fuel into each front barrel?
It's possible the carb is the problem, but even if it is, "quadrajunk" isn't warranted. Here you have the best street performance carb in the free world, and you're calling it names. For shame, for shame!
Find out if you're getting fuel to the carb. If you are, find out why it isn't getting through the carb.
Old Sep 6, 2008 | 12:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
My quadrajunk seems to work pretty good on my heavily modified 350 (cammed up too!).
http://www.youtube.com/watch?v=8PVp_l_I_Dc
check for the squirts of fuel that five seven mentioned. That's a dead giveaway if the carb is getting fuel or not. Then you can go from as to why...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
mddaniel
Sep 8, 2015 05:16 PM
greenyone
Sep 2, 2015 03:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
