rocker stud hole filling
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
i have some new aluminum heads, i just finished a port and polish and would like to fill in those holes where the rocker stud boss is tapped into the runners.
anyone have suggestions as to what to fill them with?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: rocker stud hole filling
I don't think they'd impede flow enough to worry about filling them.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
i heard somewhere that it was killing the flow by like 5% just due to turbulence. im not too worried about it right now as i went overkill with the runner size for my little 355, but when i get my 400 up and running i want all the flow i can get, plus knowing a material that can withstand the conditions in there is always nice.
thanks for your replys!
Jeff.
Jeff.
Engine: 383 Carb
Transmission: 4L60
It'd be closer to .5% than 5%... small holes like those aren't going to cause much turbulence.
Another vote for ignoring the holes. The Vortec, LT1m and some later L98 heads had the same "problem" and it was never shown to affect flow. If you are really ****, you could manufacture studs to the precise length necessary to fill the hole flush with the roof of the runner.
Regardless of what you do, I'd advise you resist any temptation to smooth over or fill the holes with any kind of epoxy or filler short of building it up with a TIG and polishing the result.
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
alright thanks, plus i guess its worth the little peace of mind that nothing is going to fall into my cylinders.
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
