base timing/ vaccum ?
Old Sep 8, 2008 | 11:15 AM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
on a stock tbi305 whats the manifold vaccum supposed to be at idle engine hot? im getting 22 with a autometer mechanical? should it be lower?
second question...
can you adjust timing with these cars using vaccum as a parameter, the vehicle im working on doesnt have a timing tab? reason im asking is because of the computer controlled advance... etc.
any help would be awesome!
thanks
Luke
Old Sep 8, 2008 | 12:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: base timing/ vaccum ?
22 inHg is fine at idle with a stock cam.
Old Sep 8, 2008 | 01:08 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
I would recommend buying a cheap timing pointer, and making sure it reads correct. All you have to do is take out the #1 plug and use a popsicle stck or something kind of soft to make sure it's close.
Old Sep 9, 2008 | 11:24 AM
Car: 92 Rs
awesome thanks for the input guys!
Pac J
May 17, 2020 10:44 AM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
rjcme
Sep 5, 2015 01:23 PM
