Re-torque bolts after initial heat cycles.
Old Sep 8, 2008 | 02:42 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I know that you are supposed to re-torque bolts after the first few initial heat cycles and engine break-in, especially with aluminum heads. Do they expect you to pull the motor? How are you supposed to get to the head bolts with headers on?
I plan on doing the initial break in w/o the trans attached. Any arguments against this?
Old Sep 8, 2008 | 05:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Re-torque bolts after initial heat cycles.
Depends on the head gaskets used - some have to be retorqued, like the steel-shim type, and some are NOT supposed to be retorqued, like the blue FelPro gaskets.
Which ones specifically did you use?
Old Sep 8, 2008 | 09:46 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Brand: GM Performance
Product Line: GM Performance Parts Composition Head Gaskets
Part Type: Head Gaskets
Part Number: NAL-10105117
Bore (in): 4.000 in.
Bore (mm): 101.600mm
Gasket Material: Composite
Compressed Thickness (in): 0.028 in.
Lock Wire: No
Quantity: Sold individually.
Head Gasket, Composite, 4.000 in. Bore, .028 in. Compressed Thickness, Chevy, 283/302/307/327/350, Each
Check to make sure this part fits your application Quality head gaskets from GM.
These GM Performance Parts head gaskets feature stainless steel faces recommended for stock and mildly modified engines. They are available for many applications and several thicknesses.
Old Sep 8, 2008 | 10:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
No retorque required
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
