Is my engine going??
Old Sep 10, 2008 | 11:54 PM
Joelfke's Avatar
Car: 1991 Camaro RS Conv
Engine: 305 V8
Ive got a 91 Camaro RS with a 305 V8. 200k miles. When i start the car it smokes whiteish smoke for a couple seconds then is fine...but when i sit at a light it will smoke when i take off. Is this just the valves? or is this the engine itself...
Old Sep 11, 2008 | 12:05 AM
JUNKYTRANSAM's Avatar
Re: Is my engine going??
200k?? gone.. valve seals, piston rings, all bearings..time fer a rebuild.
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
most of the time the white smoke is normal because condensation builds up in the exhaust system when the cars off.
but if you get white smoke when u accelerate thats a different thing, check your oil for water, anything that looks like milkshake is bad
Old Sep 11, 2008 | 07:16 AM
Joelfke's Avatar
Engine: 305 V8
well i do oil changes regularly and the oil is just dirty black nothing milkshaky...although theres a leak somewhere because if i dont watch it theres only about 2-3 quarts that come out when the oil change is done ....
Old Sep 12, 2008 | 06:03 PM
BLACK92B4C's Avatar
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
It's getting a little tired, but if it still running OK no big deal. Just keep the fluids topped off. I'd start saving for a rebuild soon! Just do a 350 while you're at it!
Old Sep 12, 2008 | 06:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, just time for new valve seals.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
