Need HELP 88 camaro starter problem!
Old Sep 12, 2008 | 11:43 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok guys a kid at my school has got an 88 camaro and everytime he trys to start it it will grind! Well he will tighten it up and it will work fine for the first start but after that it shackes loose again. Hes tried shims and cranked the bolts as hard as he could.
thanks
kevin
Old Sep 12, 2008 | 12:15 PM
CamaroRider's Avatar
Re: Need HELP 88 camaro starter problem!
The only experience I can draw on with something sounding similar is when the holes or threads in the holes (or both) are worn to the point where the contact with a NEW bolt is not tight enough. So is he using NEW bolts to mount the starter?
I have had things that would tighten (this is in a STATIC state) and then in a DYNAMIC state vibrations in the components would 'work' the bolts loose. The bolts could be re-tightened again in the static state and again work loose do to (sometimes very high frequency) vibrations in the dyamic mode.
So I would question the 'fit' of the bolt in the hole/threads. I do not even know how such a measurement could be made so that I could say it is definitely in 'as new' condition.
Last edited by CamaroRider; Sep 12, 2008 at 12:17 PM. Reason: Changed 'static' to 'dynamic' at end of paragraph 2
Old Sep 12, 2008 | 01:23 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Is he using the correct bolts with the cross hatch on them and setting the pinion/ring clearance to 18"?
Old Sep 12, 2008 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
18"? Wow, that's a long-reach starter. . .
I'll just bet you meant 1/8".
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
