Quick question
Old Sep 13, 2008 | 04:27 PM
RU1NER's Avatar
Quick question
should this be connected its just kinda sitting on top not attached or anything. thanks
Old Sep 13, 2008 | 04:30 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Quick question
just slide own over the metal and it will be fine
okmaro's Avatar
Car: Red 1991 Camaro RS
Engine: 5.0L 305 TBI
Re: Quick question
It isnt an issue, but you may as well pull the hose so it fits.
Old Sep 13, 2008 | 05:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Quick question
Welcome to TGO. It's part of the heat stove, which transfers heat from the manifold to the carb. You'll want it in cold weather.
JamesC
Old Sep 13, 2008 | 06:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Quick question
Since you're in Florida, I doubt it would help any.
It's a stovepipe to allow warm air off the exhaust to enter the carb when it's very cold outside. The warm air helps to keep the fuel from condensing or freezing in the intake.
If you install headers or an open air filter, the stovepipe wouldn't be used either.
Old Sep 13, 2008 | 06:25 PM
JamesC's Avatar
Re: Quick question
So hook it up. Can't hurt.
JamesC
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
