kick
Old Sep 13, 2008 | 07:16 PM
orangemonster's Avatar
Car: 1986 IROC 305 TPI
Engine: 1989 RS
Transmission: 5 speed
Axle/Gears: 3.08
kick
my 1986 IROC with an automatic Kicks whenever I put it in gear and use to when it shifted. It was a little low on fluid and when i filled it, it wouldn't kick when it shifted but still when it was put in gear. I checked all the mounts and the rear suspension, they were good. The only thing is the car never idles below 750, usually around 1,000. Is that too high and if so what should it be. What could be other causes. Thank you.
Old Sep 13, 2008 | 10:47 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: kick
Mine did that, adjusted the kick down cable, and flushed fluid a few times and it has helped a lot. I even have smooth but crisp wot shifts now. But mine would shift smooth when hot. After cable adjustment but before new fluid.
https://www.thirdgen.org/detent
How to ajust your kick down cable, try that first.
never mind, i just realized you have a manual, no idea how to fix, sorry.
junior419
Apr 7, 2025 11:35 AM
L0tuS
Oct 4, 2015 08:07 AM
Giocio
Oct 1, 2015 12:20 PM
mcbitchman
Sep 29, 2015 12:32 AM
tattmann
Sep 27, 2015 05:20 PM
