Engine break in question
Old Sep 17, 2008 | 11:08 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
When you have a new engine and your in the break in process is it unusual for the timing to change?
I don't remember what the timing was when I first got it going but its 12 degrees advanced now.
Old Sep 18, 2008 | 12:43 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: Engine break in question
If you're checking the timing with the timing wire connected on the electronic distributor, or the vacuum hose connected to a vacuum advance distributor, then the timing may very well change. If you're checking the timing properly, with the vacuum hose or wire disconnected, and its changed, the only reason it should is if the distributor clamp was loose.
Dave
Old Sep 21, 2008 | 12:51 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Also, make sure the plug wires are on the correct firing order and having too tight of a valve lash can also cause timing being off.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
