put a rod thru the pan
Old Sep 19, 2008 | 10:14 PM
310IROCZ's Avatar
well i went to the track today and thru a rod in my new 355 build. just so i can drive it this fall i am going to be putting in a fresh 87' 305 i have sitting in my garage. it needs a cam ,i have a new non roller cam 232/234 dur with 488 lift. a) is it to big and b) can i use my pushrod and rockers from the roller set up with non roller cam. will the length be ok? fyi 305 has nice heads ported and polished 081's 2500 stall with a th350 rpm intake and 1850 holley.
Old Sep 19, 2008 | 10:30 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: put a rod thru the pan
As long as the heads and springs can take the lift you should be fine. Roller and non roller pushrods are .6" different in length, but you could probably use stock ones. There's nothing special with the rockers so, use whatever you want.
Thornburg
Aug 25, 2015 01:46 AM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
