Need to correct the speedo
Old Sep 20, 2008 | 06:42 PM
Samdweezel05's Avatar
I installed a little bigger tire and wheel in the rear and need to know how to correct the speedo.
Phil
Old Sep 20, 2008 | 06:58 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Need to correct the speedo
there are two little "gears" in the side of the tranny called the drive gear and the driven gear, figure out your tire height and rear end gears and that will tell you which gears to get for the tranny, go to www.bowtieoverdrives.com
Old Sep 20, 2008 | 07:27 PM
For some reason I thought it was electronic. I have changed the gears in a th350 before to cure this but I thought the 700r4 would be different. Guess I need to figure what color gear I need. Thank's
Phil
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
topteam54
Oct 6, 2015 12:21 AM
TrevinE
Sep 14, 2015 03:20 PM
