heres a good one
Old Sep 22, 2008 | 04:14 PM
mark 87gta's Avatar
Car: 87 trans am gta
Engine: 355 ci
Axle/Gears: 327 for now work in progress
heres a good one
installing a 406 sbc chevy into my 87 gta everything went very well until i started to line up the torque converter bolts i rotated the crank shaft and heard a grinding noise long story short i bought a new sfi flywheel from tci ends up the flywheel is bent and rubbing the starter gear only at certain spots has this ever happened to anybody else thanx
Old Sep 22, 2008 | 10:41 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: heres a good one
ya, that's why i recommend test fitting the starter with the motor on the stand still.. in the past i've just used a washer or something as a shim and ended up with optimal tooth coverage without grinding.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
