over heating
Old Sep 23, 2008 | 10:34 PM
sjcrazyjuggalo's Avatar
Car: 92 camaro RS
Engine: v8 305
over heating
first off i own a 92 v8 305 camaro ive removed the thermostat and i have a new water pump and my radiator seems to be working fine and no leeks in the radiator hoses but my car still makes it to 260 after it runs for a few minutes befor it comes down to mornal temp i also have my ac set on normal which keeps the fan on at all times any ideas one whats wrong with the damn thing
Old Sep 24, 2008 | 03:09 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: over heating
did you try a new temp. sending unit? that was the fix for my "over-cooling" problem.
Old Sep 25, 2008 | 01:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put a proper thermostat back in.
Old Sep 28, 2008 | 12:45 AM
Car: 92 camaro RS
Engine: v8 305
Re: over heating
wouldnt it only have a overcooling problem if the thermostat was the problem and i removed it it should have solved the problem? in my old camaro i know i went through 2 or 3 heater valves but they leak when they go bad..... still stumped on this one im going to check in to see if my radiator is clogged or find other ways to open up more air flow to the radiator/engine this is really bothering me
Old Sep 28, 2008 | 12:53 AM
Car: 92 camaro RS
Engine: v8 305
Re: over heating
grr a friend of mine thinks its a blown head gasket. do you thinkg i blew a head gasket??? i really hope not
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
