Mobile 1 question...
Old Sep 24, 2008 | 12:32 AM
92GTA's Avatar
I've been running Royal Purple in my 92 GTA for the last 8yrs/130,000 miles. I decided to change and just start using another brand that is more available and affordable. I threw in some QuakerState 10w30 full synthetic the other day. Since the car has been parked for over a year I'm going to change it again in a week or so but right before I do run some motor flush through to clean everything that got gunky as a result of sitting.
Anyway, I plan on going back to Mobil 1. I noticed there is a Mobile 1 10w30 and a Mobil 1 10w40 High Mileage. What's the difference? It didn't specify on the bottles.
My engine has 201,000 miles on it and it's 100 here in the summer and 30 in my garage during winter. Winter I have been running a 10w30 and summer I run a 15w40. Should I continue doing so with the mileage I have now?
Thanks!
Old Sep 24, 2008 | 12:42 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Mobile 1 question...
stick with the regular mobil 1. all high milage oils are junk. cant fix mechanical wear with a chemical. if ur car has been doin good with royal purple it will be good on good ole mobil 1. thats what i run in my dd and i love it....not the cheapest but one of the best.....
Old Sep 24, 2008 | 06:28 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I'd stay away from the motor flush. It's been known to cause catastrophic failures.
Old Sep 24, 2008 | 07:41 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
If you want a 40 weight run M1 Turbo Diesel Truck 5W40, more detergents and anti-wear additives. I'd also recommend 5W30 instead of 10W30, same protection when hot, but more liquid during those cold, winter starts.
Old Sep 24, 2008 | 09:32 AM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ya, if you run your car in winter, use 5W30, otherwise bad things can happen, and by bad things, i mean things can blow apart from too much oil pressure because the oil is too thick.
its a little exreme, but it can happen. and has been known to happen.
Last edited by adriancamaro; Sep 24, 2008 at 09:33 AM. Reason: Automerged Doublepost
school boy
Oct 22, 2015 11:47 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Orr89RocZ
Sep 13, 2015 09:41 PM
