Fuel Pump Location ???
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I am sure my fuel pump is in the damn tank. If so I believe I have to drop the tank. I've read about cutting a hole above the tank to get to it with out droppin it. If this is possible what side is the pump on and if you have pics of this please post. Hopefully this will make my car quit stalling out then back firing. Thanks
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
Re: Fuel Pump Location ???
Car: 91 RS T-top
i will change the filter in the next day or so. I was just curious about the pump incase I do need to change it. Because I want it done by the end of the weekend and didnt want to wait on replys. The pressure always seems to be fine. I dont have this problem until I drive a mile or more.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ya, im not sure what you are gonna do but if you do replace the fuel pump, don't cut a hole in your floor. The guy that owned my car before me changed the fuel pump in 2.5 hours. (tear down, replace, put back up).
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
