Anyone ever heard of this?
Old Sep 25, 2008 | 08:56 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Ok I got a ticking noise in my 406, so after I tracked it down, it ended up being a wore out cam lobe. I got another cam and I was told the reason the cam lobe was wore, was becasue I broke the cam in with double springs. They said I should have taken out the inner spring and broke it in that way. Has anyone ever heard of breaking a new cam in that way??????
Old Sep 25, 2008 | 01:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.compcams.com/Technical/In.../Files/145.pdf
After Step 12, it says this:
"Camshaft Break-in Procedure
Important: On hydraulic and mechanical (solid) flat tappet cams that require dual valve springs, the inner spring must be removed during break-in.
Old Sep 25, 2008 | 03:28 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Re: Anyone ever heard of this?
I know it says that, but that is alot of trouble to do that on the car. I just don't see how running an engine for 20 to 30 minutes with the inner springs out is going to make. Your just going to put them right back on after that. I guess I just don't see why that would make a difference.
I guess I should have said the old cam had the back lobe wore down, I still think I got a bad cam out of the box.
Old Sep 25, 2008 | 04:19 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
There has been alot of talk over the last few years because of cam failures being linked to low sulfur and zinc content in our motor oil. There are alot of thoughts how how to prevent this. Do a search and you can learn alot.
Old Sep 25, 2008 | 04:20 PM
five7kid's Avatar
The idea of the break-in is to allow the lifter to spin in the bore so it doesn't create a lobe pattern on the heel of the lifter. Heavy spring load during or without break-in can prevent that spinning. Same reason you aren't supposed to use synthetic oil during break-in.
When I installed my last flat-tappet cam, I talked to a fellow racer who runs an engine shop. He tossed me a packet of ARP thread lube and said slather the lobes and lifter heals with that stuff, do the break-in with petroleum oil, then change the oil. Said he's never removed center springs, and has never wiped out a cam.
Also understand the issue lately with ILSAC GF-4 oils and reduced anti-wear additives. Use of a dual diesel/gasoline rated oil is suggested, as the diesel oils still have those additives. As long as it has an SL rating along with the CI-4, it will be fine.
Old Oct 1, 2008 | 09:33 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Kendall gt1 20w-50 is the only motor oil still out with a SL certification for high zinc content. Also the diesel oils, eg: shell rotella t 15w40 and chevron delo 400 15w40 (the older version that isn't low emission), will have a high content also. If you choose not to run any of those oils then you could try a bottle of the GM EOS part# 88862586.
Old Oct 1, 2008 | 02:05 PM
five7kid's Avatar
Not true. AMSOIL has several diesel oils with the anti-wear additives, with both CI-4+ and SL ratings.
EOS is for assembly and run-in only. It is not intended as a running additive.
Old Oct 1, 2008 | 02:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
EOS is sold to be used as a running additive as well. To "quieten lifter noise" etc etc. I would use that as an additive with "normal" oil, since I can't figure out which oils have the right additives for my motor anyway...
Yea, wiping a cam when you left in both springs sounds about right. Yea it's a pain in the ***, but so is making sure you torque up all your cylinder head bolts in order, and go over them twice. But hey, you do that don't you? And then you don't have any head gasket leaks either
Old Oct 1, 2008 | 03:00 PM
five7kid's Avatar
Not by GM.
Old Oct 1, 2008 | 03:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'm just going by what it says on the bottle... I figured GM wrote that..?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mcbitchman
Sep 29, 2015 12:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
