timing help
Old Sep 27, 2008 | 07:34 PM
stakkattakk's Avatar
timing help
Hi I have a 87 tpi engine it doesnt run good when slightly pushing on the gas boggs kindof so I thought to check timing, to loosen the distributor does the bolt underneath need to be loosened to turn the dis, and if so how do u get a wrench down there too loosen it, or does it take a special wrench thanks?????
Old Sep 27, 2008 | 07:53 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: timing help
you can check your timing, but how's the ignitions system? are you getting enough fuel pressure? good spark?
Old Sep 27, 2008 | 08:13 PM
Re: timing help
well when slamming down the pedal so to speak it takes off great but is just just shaky when barely pushing the gas and when it gets hotter it gets funnier can run on.and almost stalls at times , but running cold it does better
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
