VACUUM SEEMS LOW AT 5-7psi
Old Sep 28, 2008 | 12:11 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
You can see the specs of my motor in my sig listed below. I have total advance set at 36*, set idle mixture screws to 1 1/2 turns out and seems to run better between 1 - 1 1/8 turns out. PV on primary is 2.5 and 78 jets all around. Had the heads off recently to have them checked for cracks, new springs installed, re-surfaced and new head/intake and exhaust gaskets. Was having low vacuum before I did any of this also.
Maybe this is normal for my cam, anyone have any input?
Old Sep 28, 2008 | 12:17 AM
mcbchild's Avatar
Re: VACUUM SEEMS LOW AT 5-7psi
I also set the primary throttle blades to .040 below the transition slot.
Old Sep 28, 2008 | 12:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's a heap of duration, so I wouldn't call it excessively low.
BTW, it's inch-Hg, not psi.
Old Sep 28, 2008 | 08:01 AM
mcbchild's Avatar
So with that duration it's about in the correct range?
BTW, I knew it is in inch-Hg and don't know why I put in psi. Guess I was thinking compression.
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
amcnellis
Sep 16, 2015 04:16 PM
adelane
Sep 9, 2015 08:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
