Rubbing/grinding sound from passger side front area
Old Sep 28, 2008 | 10:39 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I am getting a grinding sound from the front passenger side. I jacked the car up and I seem to have a click when I put my hand at 12 and 6 on the wheel. If I am on the highway i get vibration and sometimes if I slam the brakes it shifts and the noise goes away. I do have a wacked alignment that pulls to the right. Things look ok underneath. Tires are brand new.
Old Sep 28, 2008 | 10:47 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Rubbing/grinding sound from passger side front area
Change the wheel bearings before it locks up and ruins the hub or spindle. The "goes away when I put on the brakes" is a dead give away for a bad wheel bearing.
And do both sides because the other one is probably not far behind.
Bearings are cheap, like $5-6 each.
Old Sep 28, 2008 | 07:38 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
kind of a no brainer IMO . fix it now , new bearings are cheap . replace , grease properly , new seals , good for as long as you own the car . good luck .
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
db057
Aug 22, 2015 08:17 PM
kyleb24
Aug 15, 2015 08:24 AM
wruiz
Aug 11, 2015 02:59 PM
