How do u take an 02 sensor out. Please help
Old Sep 28, 2008 | 02:21 PM
bcfipp's Avatar
car is a 1991 chevy camaro z28 305 tpi. How do u take the sensor out to replace it thanks.
Old Sep 28, 2008 | 03:32 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: How do u take an 02 sensor out. Please help
you should be able to get an 02 sensor wrench from autozone. when you go to take it out make sure the engine is warmed up and it will be easier to take out.
Old Sep 28, 2008 | 03:41 PM
bcfipp's Avatar
I tried but i think the sensor is rounded out
Old Sep 28, 2008 | 03:45 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Its going to be extremely hard to remove if its the stock one. But you can get the special O2 Socket that might help. I just used an adjustable crecent wrench and alot of sweat... Try to get as much leverage as you can!
Old Sep 28, 2008 | 03:46 PM
Engine: L69 H.O
Hmmmm do you have any pictures are you sure the bolt is stripped out or is it the wrong size wrech. Chevy used a combination of standard and mm bolts on our cars dont remeber what size the 02 sensor is though
Old Sep 28, 2008 | 03:55 PM
bcfipp's Avatar
I can look at it and see that it is stripped. Auto zone gave me the tool to take it out but it won't break loose at all. How can u get in there with a wrench. take some the egr stuff out of the way?
Old Sep 28, 2008 | 05:04 PM
Engine: L69 H.O
you just have to put the wrench in different positions till you find the one that works you wont be able to turn it much but should be able to turn it enough for it to break loose
Old Sep 28, 2008 | 07:11 PM
bcfipp's Avatar
there is no room i tried to get a wrench in and it still wouldn't break loose. should i use a torch to heat the sensor up
Old Sep 28, 2008 | 07:23 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
What about trying PB Blaster to losen it up?
Engine: L69 H.O
i guess you could use a troch but you take the chance of burning some wire i just let mine idle up to operating temp then shut it off and it came out pretty easy but i ended up burning my hand i dont know how different your engine bay is since you have a different year but i had just enough room to get it out
Old Sep 28, 2008 | 07:49 PM
bcfipp's Avatar
ok i tried the pb blaster i will try again tomorrow i was getting to frustrated. I bought a channel lock but it was to small. thanks guys for the help
Old Sep 28, 2008 | 08:09 PM
Engine: L69 H.O
just keep trying eventually you should be able to get it to break loose you may end up taking the whole manifold off just to get it out ive had to do that before
Old Sep 28, 2008 | 08:21 PM
mesterz2889's Avatar
i used a zip wheel on a 6 point closed wrench and cut out a slot for the wire and then cut the wrench in half for room to move may be different for you tho good luck
Old Sep 28, 2008 | 08:24 PM
Engine: L69 H.O
never thought about doing that
Last edited by blackandgoldl69; Sep 28, 2008 at 08:27 PM. Reason: Automerged Doublepost
Old Sep 29, 2008 | 04:03 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Did mine last week.....soaked it good the night before with PB Blaster then the next day went for about an hour cruise then came home and used a breaker bar with a small extension and the sensor removal socket and it came right out (breaker bar is the key).
Old Sep 29, 2008 | 10:03 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Just don't forget to anti-sieze the threads and you wont have that problem. Also helps if you pull it out and reinstall once a year.
Old Sep 29, 2008 | 04:23 PM
bcfipp's Avatar
still no luck about getting the o2 sensor off. any other suggestions. thanks for bearing with me
Old Sep 29, 2008 | 07:19 PM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Have you tried using 1/2" or 3/4" drive breaker bar with a pipe extension for leverage?
Old Sep 29, 2008 | 07:31 PM
bcfipp's Avatar
yes the only thing i haven't tried is the torch
Old Sep 30, 2008 | 12:38 AM
webeeZ28's Avatar
Engine: 5.7 350 B2L
Since you say it is rounded off, have you thought about finding a socket that will fit it very snug like and hammering it on the sensor? Hopefully the fit will be so tight that it won't slip and then try the breaker bar again. Of course if you're successful, you most likely won't be able to use the socket again. I have used this technique myself on other applications. I can always buy another socket. Good luck.
Old Sep 30, 2008 | 06:00 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
The o2 sensor sockets often flex and skip over the hex. At least my cheapie does.
On my old truck (or was it the 'bird? T'was years ago.) I broke the top off of the sensor and put a regular short socket and breaker bar on the hex and threaded portion left behind. In your case you might be able to get one of those Craftsman bolt-outs on the remains and back it out. After letting the PB blaster soak for a while, days if necessary. Of course once the sensor is broken, there's no going back.
I wouldn't recommend banging a smaller socket on there. Assuming that you could even find room to swing a hammer, you're sharply banging on a fairly thin pipe. I'd hate to see you crack something.
Old Sep 30, 2008 | 11:27 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Along with heat and the liquid spray you could also tap the sensor with a rod and a small hammer, sometimes the tapping is just enough to help loosen things up. Later.
Old Oct 1, 2008 | 12:23 AM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Stock manifolds or headers? either way you could always remove whatever is on there so you can actually get at it, and if it stock, a perfect excuse for headers...
Old Oct 1, 2008 | 03:43 PM
bcfipp's Avatar
The sensor finally came out. Thanks everyone for your help and advice.
Old Oct 1, 2008 | 11:01 PM
webeeZ28's Avatar
Engine: 5.7 350 B2L
That's it... cmon bcfipp... you gotta tell us what it finally took to get it out.
Old Oct 2, 2008 | 08:55 AM
bcfipp's Avatar
Putting a torch on the sensor for 15 mintues, after spraying it with pb blaster then taking a 7/8 long socket. hammered it over the sensor. Then used a breaker bar to and it finally broke loose
Old Oct 3, 2008 | 12:34 AM
webeeZ28's Avatar
Engine: 5.7 350 B2L
You da man! Here's to your persistence ...
92firebirdguy
Sep 1, 2016 07:53 AM
amcnellis
Sep 16, 2015 04:16 PM
earlpote
Sep 12, 2015 11:55 AM
FormulasOnly
Sep 10, 2015 09:07 PM
willyjoejr
Sep 3, 2015 09:26 AM
