PVC
Old Sep 28, 2008 | 08:19 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
PVC
does it matter which hole in the rocker cover the PVC valve goes in? baffled or no baffle? I want to put my filtered breather in the baffled hole.
DO we really need to have a PVC system hooked up to the motor? what happend if I remove the PVC and just plug the hole in the plenum?
Old Sep 28, 2008 | 08:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: PVC
The PCV valve goes in a baffled hole to keep it from ingesting oil.
You don't need a PCV system, but you really want one.
Old Sep 28, 2008 | 08:47 PM
Re: PVC
ok so what will happen if I plug the hole under the plenum and just put a cap over the hole in the rocker cover?
Old Sep 28, 2008 | 08:58 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: PVC
I asked like the same thing.
https://www.thirdgen.org/forums/tech...ml#post3902113
Should answer your question.
Old Sep 28, 2008 | 09:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: PVC
You'll vent vapours out the breather, and you'll have increased oil contamination.
Old Sep 29, 2008 | 07:57 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: PVC
Why not just swap the valve covers from one side to the other?
Quzyle
Oct 15, 2015 03:35 PM
BurlyChev
Aug 22, 2015 01:52 PM
mustangman65_79
Aug 8, 2015 12:07 PM
jerflash
May 3, 2002 11:31 PM
3.1EyeCandy
Aug 29, 2001 09:43 PM
