wont' stay running
Old Sep 28, 2008 | 09:35 PM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
wont' stay running
car runs for about 2 seconds then dies. I unplugged the coolant or temp sensor located next to the thermostat on top front of the motor and it ran fine but at a real high idle. thought sure that was my problem. installed a new sensor, plugged it back end but car only ran for a couple seconds. I unplugged the sensor and car ran fine again but real high idle. I decided since the car was running now I could take it to the shop. I started it once more with the sensor disconnected to see how long it would run before I got out on the road. It did run for 3 minutes or so at high idle but then died and now with the sensor plugged or unplugged it will just run for a few seconds. The battery was bad and I replaced it but still the same problem. I also changed the fuel filter. It the fuel pump is bad I would not think it would have run for the 3 or 4 minutes or so. Need help, would like to take it to Cruising the Coast next week.
Old Oct 2, 2008 | 04:20 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: wont' stay running
Any SES lights ?
Checked the basics like sparkplugs, wires, fuelpressure ?
Grounds ?
Fronzizzle
Mar 18, 2019 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
Sherpajames
Aug 7, 2015 06:56 PM
