Coolant sensor, dash gauge
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
I put a new sensor on the intake for the dash gauge and its still showing pegged out all the way to the top. It was like this when the green wire wasn't hooked up, so I picked up a new sensor and thought it would read rite but nothing. Any info would be greatly appreciated, Oh ya the oil pressure shows the same too
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Coolant sensor, dash gauge
The sender for the gauge is not in the intake, it is located on the driver head in between the #1 and #3 spark plugs. Check there for the wire to be grounded or the sender could be bad itself.
Car: 87iroc
Yes I'm aware of that, but I put a autometer temp gauge there and kinda of burnt the cable from the header. The original sensor was moved over to the HSR intake. Still not getting a read off the dash gauge, I figure its the green wire as the sensor is new.Just waiting to get the autometer replaced but thought it wouldn't hurt to have the dash gauge working as well. THNX
Car: 1989 Iroc-z
In that case, it sounds like you have a problem with power going to the gauges, the gauge itself is bad or its a wiring issue. Could be the same with your oil pressure gauge.
ambainb
Apr 25, 2016 09:21 PM
