help! aft market oil pressure gauge?
Old Sep 29, 2008 | 08:34 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i have just bought a oil pressure gauge and im trying to figure out how to put it in? somebody please help tell me how to put the sensor in?
Old Sep 29, 2008 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: help! aft market oil pressure gauge?
Find an available oil galley port and screw it in.
Old Sep 29, 2008 | 08:41 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
The sensor is in the back of the motor by the firewall. It just unscrews from an angled tube that comes up from the intake. It sound have a wire going to it. Its long and round. Its not difficult to replace.
Old Sep 30, 2008 | 12:21 AM
Car: 02wrx/88 rs
now that part i just take out and put in mine? and thats on my motor? 91lo3?
Old Sep 30, 2008 | 02:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, not on your 91 engine.
There are 2 places you can install it. Either at the top of the block behind the intake near the distributor where you should have a pipe plug right now, or on the side of the block above the oil filter where the factory switch/sender is.
Old Oct 1, 2008 | 07:11 PM
Car: 02wrx/88 rs
i looked behind the dis. couldnt find the plug? am i just not looking hard enough? i would hate to screw with the computer so i dont want to remove stock sensor.
Old Oct 2, 2008 | 02:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The computer doesn't know or care about oil pressure, so you can't mess it up. The stock OPSU/switch only operates the stock gauge, and acts as a backup to the fuel pump relay.
It's not really behind the distributor, it's more beside it, on the block itself behind the intake manifold, between the two heads.
Old Oct 2, 2008 | 04:54 PM
Car: 02wrx/88 rs
ok so the one on top the oil filter will work? along with the one on top the motor? and a backup? how? sorry to ask so much just trying to learn
Old Oct 2, 2008 | 05:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Either one of those will work.
Old Nov 21, 2018 | 02:06 PM
backtothe80s's Avatar
Engine: 350-TPI
Transmission: 700-R4
Axle/Gears: 3.27 Posi
Mispost, please disregard. Sorry!
Old Nov 21, 2018 | 02:33 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
I used the port in the back of engine (next to distributor) for the Oil pressure, and the one on top of the oil filter for my oil temp.
Old Nov 21, 2018 | 07:12 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
There also is another 1/8" pipe plug behind the water pump just to the right side of center about the timing cover that's good for a pressure gauge or a temp sensor.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
