Aftermarket Cylinder Heads
Old Oct 1, 2008 | 04:41 AM
cmack's Avatar
Car: 1983 camaro
Engine: 383sbc
Hi i was wondering anyone could suggest a set of cylinder heads for my car
i'm looking for 60-64 cc combustion chambers and 195 to 200 cc intake runners. The heads are going on a 383 strocker with a soild roller cam with .553 intake .576 exhaust lift or higher.i need to have straight plug style if anyone can suggest a good set let me know i was looking a these heads tell me what you think. and what about 2.05 intake valve worth it or not
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 8, 2008 | 11:42 AM
10secondhopeful's Avatar
Car: '84 Z28
Re: Aftermarket Cylinder Heads
depends on what price range your looking at...AFR, pro comp, Lingenfelter, all make good heads for about 1400 all with the specs you want and more
Old Oct 8, 2008 | 02:13 PM
mdpierce8's Avatar
Car: 1987 Camaro Sports Coupe
Engine: 305 4bbl
VORTEC
Old Oct 8, 2008 | 03:23 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You are already at the maximum lift of those heads with that cam. You cannot go bigger on the lift without work. I was looking at them but they were not set up for EGR as near as I could tell. My car needs to be smog legal.
They seem to be a decent head. I went with AFR myself. I don't know what your goals are but if looking to get the most power out of your setup go with the best heads you can afford.
Chuck84TA
Jul 15, 2016 09:05 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
ZsTransAm
Aug 11, 2015 07:30 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
