Vacuum Hose Size
Old Oct 7, 2008 | 09:06 PM
BlueSSZ28's Avatar
Vacuum Hose Size
305 CC 4bbl Qjet LG4
Anybody know all the sizes of rubber under the hood? (Maybe someone who recently replaced all theirs)
I'd hate to get out there and start ripping out vacuum hoses and measuring, buy new and then spend a day routing it all.
Sorry if this is a mundane question.
P.S. Whats that hose called that comes from the bottom of the air cleaner into the engine, About 1-2 inches long and looks like a mini dryer hose
Old Oct 8, 2008 | 09:43 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Vacuum Hose Size
What year car?
Should be mostly 7/32". Close to 3/16", but not quite. There's also some 3/8" (brake booster line).
mini dryer hose - exhaust heat riser. Gives warm air to air cleaner for cold starts. You should have a thermal (vacuum operated) switch to open/close that opening on the bottom of your air cleaner.
Old Oct 8, 2008 | 04:21 PM
BlueSSZ28's Avatar
Its an 86
Thanks for all the info, Think 10 foot should do it or should i get 20?
Old Oct 8, 2008 | 04:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
You're replacing every hose under the hood? I have no idea how many of the emissions equipment use that style of hose, so I wouldn't even want to guess... Or how much of those you still have. Your guess is better than mine!
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
m00n420
Sep 11, 2015 02:39 PM
timonator
Sep 10, 2015 07:55 PM
