Can sluggish EGR cause idle changes?
Old Oct 2, 2008 | 02:58 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I can not find any vaccuum leaks on my L98 TPI. I do know that the EGR is starting to fail. I also have a problem with my idle occasionally changing from 700rpm to 900rpm. Could the EGR cause this during cold or warm start-up?? Nitro-Nicky
Old Oct 2, 2008 | 04:03 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Can sluggish EGR cause idle changes?
Bad EGR could cause alot of strange problems. Bad idle, shaking.
So have it pressure tested and see how it is. Or change it if you are sure its on the way out.
IROCtometal
Sep 20, 2015 11:08 PM
Kenwood
Sep 11, 2015 12:50 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
rjcme
Sep 5, 2015 01:23 PM
