aluminum head problem!
Old Oct 5, 2008 | 10:21 AM
johnfwz28's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
guys, i have some aluminum heads from a 91 vette. i bought them from the guy who rebuilt my engine. he installed the heads on my 350 camaro engine. now i'm putting all the top end of the engine back on. i have everything all buttoned up. yesterday i was putting the plugs & wires in,and found that the cylinder #8 (the hardest plug to install,because of the headers)spark plug hole seems to be stripped,or crossed threaded.the plug will go in, and i can snug it up with my fingers but it will become loose again if i try to move the plug left or right,or up & down. i really don't want to undo all the top end and pull that head off. what can i do short of taking that head to a machine shop? my friend suggested wrapping teflon tape around the plug,but i'm not sure about that. what do you guys think? any replies will be greatly appreciated!
Old Oct 5, 2008 | 10:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: aluminum head problem!
Use a Helicoil.
Old Oct 5, 2008 | 10:27 AM
johnfwz28's Avatar
Engine: 5.7L TPI
yeah, i never thought of that. i've never used one b-4, not sure exactly how to do it. do i use the same size as the hole or same size as the plug?
Old Oct 5, 2008 | 10:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take your spark plug to the parts store and tell them you want a helicoil kit to fit it.
Old Oct 5, 2008 | 10:38 AM
johnfwz28's Avatar
Engine: 5.7L TPI
thanks man, what do you think of my friend's suggestion? wouldn't teflon tape break down because of the gas?
Old Oct 5, 2008 | 10:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, but teflon tape is for sealing thread-sealed fluid connections. It won't do anything for your mechanical problem.
Old Oct 5, 2008 | 01:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Also note that the spark plugs for those heads are a 3/4" reach, flat gasket seat. Which are different from the spark plugs that the iron heads used.
The Autolite 3926 are the stock 'Vette plugs. Probably be better to drop a couple of heat ranges and use the Autolite 3924 plug.
RBob.
Old Oct 5, 2008 | 03:25 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Good luck getting helicoil into #8. It's not going to be fun.
Old Oct 5, 2008 | 03:49 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Is it actually possible to get a helicoil in here without removing the head?
Old Oct 5, 2008 | 05:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is the engine in the car?
Old Oct 5, 2008 | 05:25 PM
jv9999's Avatar
Engine: 5.7L/350
It may be possible, but I'd pull the head. It will be easier and safer in the long run.
Old Oct 6, 2008 | 09:39 PM
johnfwz28's Avatar
Engine: 5.7L TPI
Hey Apeiron, today i tried screwing a shorter plug in that #8 hole,and it snugged up finger tight and din't move. The original plugs that i was using are NGK FR-4's they have long threads which are supposed to be used with aluminum heads. the short thread plug i used was just an old Champian cast iron head plug that i had lying around. I wonder if i can just use a new set of AC Delco's that are designed for cast iron heads? The engine IS in the car, so trying to use a Helicoil or tap & die set is going to be a major pain!
Old Oct 6, 2008 | 09:53 PM
johnfwz28's Avatar
Engine: 5.7L TPI
no. jv9999, it wouldn't be easier to pull the head off. i recently spent a lot of time closing the top end up. putting on the upper and lower intakes, the alternater and all of the brackets, the distributor, etc... all of that would have to be undone to pull the head off.(maybe i'm just too lazy)
Old Oct 6, 2008 | 09:56 PM
jv9999's Avatar
Engine: 5.7L/350
In that case, you could probably do it if you pulled the exhaust manifold.
Old Oct 6, 2008 | 10:02 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Can you pull the header off use the helicoil then put the header back on?
Old Oct 6, 2008 | 10:16 PM
johnfwz28's Avatar
Engine: 5.7L TPI
yes. after explaining my perdicament(spelling?)to a buddy who has his own high performance shop, that is exactly what he suggested. in fact he told me to call him back when i have the header off and he will come over to tap it out for me. i'm glad i thought to call him. just got off the phone with him.
Old Oct 6, 2008 | 10:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No you can't. A cast iron head has a tapered seat around the plug hole that seals with a matching tapered section on the plug. An aluminum head has a flat seat and the plug seals with an aluminum crush washer.
"Finger tight" isn't much of a test of the fitness of threads anyway.
Old Oct 6, 2008 | 10:42 PM
johnfwz28's Avatar
Engine: 5.7L TPI
yeah, i know. but if i tighten it with a wrench, i believe it will lock down. ok how about this, a plug thats designed for aluminum heads but have short threads like the cast iron plugs. is there such a creature?
Old Oct 6, 2008 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are, but if you use a shorter-reach plug, the spark will be firing back inside the plug hole instead of out in the chamber where it'll do some good.
Old Oct 6, 2008 | 10:50 PM
johnfwz28's Avatar
Engine: 5.7L TPI
so would a hotter plug solve that problem? you seem to be very knowledgable about this stuff, i'm sure you can figure out something for me!
Old Oct 6, 2008 | 10:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, plug temperature wouldn't address that at all. The right thing to do is fix the threads and use the correct plug.
johnfwz28's Avatar
Engine: 5.7L TPI
i have a MSD coil and 6a box that i plan to install. will that help?
Old Oct 6, 2008 | 10:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No. Fix the threads.
Old Oct 6, 2008 | 10:55 PM
johnfwz28's Avatar
Engine: 5.7L TPI
ok i guess i have to pull the header off and take care of this problem using a helicoil kit.
thanks Apeiron, you have been very helpful, keep up the good work! by the way do you drag race?
Old Oct 6, 2008 | 11:09 PM
Guest
Guest
Posts: n/a
The factory L98 AL head will accept either plug style, it just needs to be a long reach plug.
Old Oct 6, 2008 | 11:25 PM
johnfwz28's Avatar
Engine: 5.7L TPI
yeah Madmax, the problem is the long threaded plug won't lock down. i'm just gonna have to fix the problem like Apeiron said. good nite fellas. it's midnight here in Georgia now,and i do have to go to work tomorrow.
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
