AC removal
Old Oct 6, 2008 | 02:07 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
AC removal
Hey Guys,
I want to remove my Air Condition because itīs broken and I wont use it anymore.
So my question is, when I remove the compressor the belt is much too long.
Can somebody tell me how long the belt has to be when not using the AC.
Or has somebody a car without AC and can tell me the right length of the belt???
Thanks Rob
Old Oct 6, 2008 | 02:22 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: AC removal
you dont need to replace the belt, but if you want to i think the length of belt you need is 44"ish, but i would double check that. I've been running mine for 2+ months without the A/C belt and never had a belt slip, but the only reason I didn't replace the belt was because napa didn't have one the correct length.
Old Oct 6, 2008 | 12:22 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: AC removal
You can get an ac delete pulley any bracket. Its what would of been installed on a thirdgen that didnt have ac from the factory.
Old Oct 7, 2008 | 05:12 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Re: AC removal
Ok, thats just fine... Do you know where to buy? jegs, summit, autopartswarehouse???
Itīs called "AC delete pulley" right? then I can do a search.
Ok, did the search and found some in the www.
But thats not exactly what I want!
Canīt I just buy a shorter Belt? Does somebody know the length I would need??
Thanks Rob
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
