Int stall.
Old Oct 6, 2008 | 08:20 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Int stall.
Hi,
I have a 92 5.7 GTA. The engine "stopped" on me and i was required to get a flat deck ride home, now here is the story.Car was working great i speed up to pass a car and there was a "miss" but only for a second then i made the pass and kept driving. Shortly after this i stopped to run some errends and the car restarted fine and i continue, agian i hear this "pop" or sneeze sound so i slow down pull over and check it out at idle, everthing is fine. I do have a fuel pressure guage perm mounted on the engine so i was able to see it, i tried to accel but the car sneezed again and stopped. with no restart. To my suprise the batt would only give me about 5-10 seconds of trying then it died. I installed a new battery from a dealer and it would crank but not fire.
After the flat deck ride home the car started the next morning but it was running very rough for a min or so after that it purrs just as if nothing has ever happened! I am asking you folks what /where should i beging to look at as my faith in her is long gone after this horrible weekend, thanks GTA
Old Oct 6, 2008 | 08:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like a weak ignition. Either ignition control module or coil, good chance it's both.
Old Oct 6, 2008 | 08:27 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: Int stall.
I just replaced my coil with a MSD blaster coil i still do have the stock one , and i do also have stock ign module
Old Oct 6, 2008 | 02:00 PM
five7kid's Avatar
Stock modules are know weak units. They are also known to take out a good coil when they go bad. Works the other way, too.
Old Oct 6, 2008 | 06:31 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: Int stall.
five seven, thank you for your reply, I found the trouble, a poor connection to the ecm it started and died on me again, checked with a scanner and noted no comm with ecm, a quick wiggle of the wires and like magic it fires to life looks like this entire mess was my own fault, modded too much again thanks GTA
antman89iroc
36
Jan 31, 2016 08:42 AM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
WhteRbt
Sep 21, 2015 09:48 AM
buckshot63
Sep 10, 2015 09:15 AM
