SES light
Old Oct 6, 2008 | 08:39 AM
drfrankenstein's Avatar
SES light
so i was trying to pull my CEL codes. i have a 87 auto ta with 305 4bbl, the cel is on i know one of the codes should be o2 and one should be from the lack of a smog pump, however i want to know exactly what codes are stored, but my 12pin connector only can with pins 1,3,4,5,6. all else are just empty ports. i tried jumpin 5 and 6 with my GM code key but no luck, and jumpin 6 and 12 isnt an option cause i dont have anything in 12 but i tried it anyhow (jus for heck of it) no good. so is there anyway to check my CEL since i cant manually do it? do i like need to pick up one of them obd1 GM code scanners?
Old Oct 6, 2008 | 02:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: SES light
It should be the upper right two pins, then turn the key on.
Old Oct 6, 2008 | 03:23 PM
Re: SES light
well that dosnt work for me, maybe my car is a tad bit gay. like not being sarcastic im being serious, im like no rookie at all, however this car is making me feel like one.
Old Oct 6, 2008 | 05:01 PM
jv9999's Avatar
Engine: 5.7L/350
Re: SES light
Does the CEL come on when you turn the key on? ie, does the bulb work?
Old Oct 7, 2008 | 10:01 AM
Re: SES light
bulb does work, but the light wont flash not even the 12 code. it comes on and just stays steady.
Old Oct 7, 2008 | 10:45 AM
jv9999's Avatar
Engine: 5.7L/350
Re: SES light
Does it come on when you turn the key on but don't start it?
Old Oct 7, 2008 | 01:00 PM
Re: SES light
yes sir. comes on and stays that way with key in on position not runnin
Old Oct 7, 2008 | 03:42 PM
jv9999's Avatar
Engine: 5.7L/350
Re: SES light
Then it's probably time to start looking at the wiring. You might try reseating the ECM connector. Do you have a voltmeter (not a test light)? You can check for ground on the upper right terminal and 5V or so on the one to the left of it.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
