cars is desieling ??????
Old Oct 6, 2008 | 09:24 PM
firbster's Avatar
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
car is an 84 z28 with the 5.0. h.o. motor , when i turn it off the car desiels for a couple seconds ,, what causes this to happen? amd what would be the fix?
Old Oct 6, 2008 | 09:29 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: cars is desieling ??????
Plugs too hot is all I can really think of. Did you get the recommended plugs for the HO engine?
I guess poor cooling system performance in the heads could help contribute as well.
Other than that, I dunno.
Old Oct 7, 2008 | 12:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
There's a few things that will cause that;
-plugs too hot (rare)
-carbon deposits on piston crown/chambers (run top end cleaner/water through engine)
- too much timing (common)
- throttle open too far (very very common)
If your choke is still hanging open, secondaries hanging open, idle is too fast, vacuum leak, etc. Those will all cause it. If you have a 1300RPM idle and you shut it off, that's why...
Old Oct 7, 2008 | 03:57 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
1. run some seaform through engine.
2. double or tripple check your timing.
3. check your plugs (see what they look like) good for diagnosis.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
