305 or 350???
Old Oct 7, 2008 | 02:43 AM
mikebaker87's Avatar
305 or 350???
Any way to tell the difference between a 305 or a 350 in a camaro without seaching out the the block #s or not where they are located, guy says it is a 350 carb out of 87 trans am, only 305 had carbs that year not 350's so any help is gladly welcomed, thanks.
Old Oct 7, 2008 | 04:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 305 or 350???
The only absolute is to look for a 50 or 57L on the rear top driver's side of the block by the trans.
Old Oct 7, 2008 | 04:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 or 350???
Thirdgens never had 350s from the factory with anything except TPI.
Old Oct 7, 2008 | 04:12 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: 305 or 350???
you need the casting #'s...
locations
http://www.mortec.com/location.htm
casting numbers
http://www.mortec.com/castnum.htm
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
