water pump bolt question
Car: 1987 Formula 350
Axle/Gears: 10 bolt 3.73
Ok, this is pretty embarrassing. There are 4 bolts holding on the water pump for my engine (obviously, right), one of them has a stud on the end, and the other three are normal bolts. My problem is, I pulled the pump quite a while ago and I forget where the studded bolt goes. Yeah yeah, I know, I'm an idiot. Sooo..instead of guessing and most likely having to remove it again, does anyone know which hole the studded bolt goes into? I have an '87 Firebird Formula 350. It is an L98 350. My alt is on the passenger side, most pics I'm finding have it on the drivers side, so I don't know if that affects what side the stud goes?? Thanks to anyone that can help me out.
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: water pump bolt question
From what I remember the stud was on the driver's side. I don't have an L98, but helped a friend replace his water pump.
2011 Norwood Gathering
ThirdGen Camaro Rep
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Assuming you don't have a serpentine set up, looking at the front of your motor the stud goes in the top right hole and is used for an accessory bracket.
eightsixseven
Dec 16, 2024 01:50 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
