500 caddy into iroc
Old Oct 7, 2008 | 07:38 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
500 caddy into iroc
My buddy just picked up a 500 big block caddy motor for real cheap and we got the insane idea of throwing it into a third gen camaro. What would be need to make it all work?
edit-shoulda put this in engine swaps damnit
Old Oct 7, 2008 | 08:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 500 caddy into iroc
Anything can be made to fit with enough time and money but this isn't a simple drop in engine swap.
You'll need a different transmission because a chev bolt pattern tranny won't bolt onto a B-O-P-Caddy engine. You can use BBC headers with Caddy flanges welded onto the tubes. Just about everything else will have to be fabricated.
There is no cheap performance potential to using a Caddy engine. It can be a lot cheaper and easier to drop in a BBC.
If you use the search feature, you'll see that others have already asked about doing a Caddy swap.
If you want Caddy performance parts, this is your only source.
http://www.cad500parts.com/
Old Oct 7, 2008 | 08:20 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
i searched but i didnt have no luck i guess. we are trying to do it on the cheap i know we would need an adapter plate for the tranny and we were just gonna use exhaust manifolds to make life easier
Old Oct 7, 2008 | 11:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Duplicate of post in the Engine Swap forum.
ex-x-fire
Jan 12, 2024 01:58 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
