first timer
Old Oct 8, 2008 | 02:23 PM
bdb1980's Avatar
first timer
this is my first time the on this sight. im in the middle of a project. i have a 91 z28 with 5 speed trans. i took the 305 out and im in the process of buiding a 383. i bought a short block from engine kit .com. i just purchased a top end kit wich is Trick Flow 500 HP Super 23 Top-End Engine Kits for Small
Block Chevrolet. i dont know what a good combo would be as far as carb and intake , any suggestions would be helpful thanks
Old Oct 8, 2008 | 02:39 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: first timer
its really hard to give u good advice on this. basically what is your preference. some guys are gonna push for u to slap on a thousand bucks worth of aftermarket FI equipment although i havent seen that too much on here. if it were i, slap on a good aftermarket high rise such as the performer RPM and a good holly. if your in the 500 hp range id say 750 to 850. are u gonna be sprayin that stroker? im sure some one will pop in now that i said something to ya. people are prone to disagree.
Old Oct 9, 2008 | 09:38 AM
bdb1980's Avatar
Re: first timer
i wont be spraying the motor but i just want to get as much out of the motor as possible. i was thinking about a barry grant 750. i been doing some research and ive seen some people putting different combos. this car will be a weekend driver just something to have some fun in. i also heard that the headers for this car have to be right on because of the spacing under the hood ,so im having trouble finding them because the ones that i have seen are for fi. any suggestions?
Old Oct 9, 2008 | 11:33 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: first timer
I agree with above on the edelbrock rpm and holley, as far as headers go, i'd go with a major manufacturer (ie. hooker or hedman, and though i have no experience with them i have heard the dyno dons are good). for that particular question i'd go over to the exhaust board, cause they got some stickies with alot of information so you could make an informed decision, cause everyones going to say something different.
(BR)G-Machine
Aftermarket Product Review
Mar 16, 2004 09:20 AM
(BR)G-Machine
Mar 16, 2004 09:12 AM
wjbecker
Mar 13, 2004 06:21 PM
BOTLFED
Aug 8, 2003 12:34 PM
