New underdrive pulleys
Old Oct 18, 2008 | 01:10 PM
System1's Avatar
Car: 1988 iroc camaro
Engine: forged 383 tpi
I have a 5.7l 350 1988 iroc camaro. I've done a 383 engine swap, and i'm to the part where i add underdrive pulleys. The set i have is the bbk version, and the crank pulley looks to be 6" as opposed to the 8" stock. My question is what size belt do you guys suggest for this upgrade? Also i've been reading about the the smog pump delete and i've found the part number on the board where just a smog pumo has been deleted. If i choose to get rid of mine, what size belt would i need with a deleted smog pump and underdrive pulleys. I think the stock is around 98". Thank you for your help.
Old Oct 18, 2008 | 04:17 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New underdrive pulleys
Your best option is to get the pulley deal done, run some string around everything, measure the string, then subtract an inch or two for the tensioner.
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
