Sometimes runs weird?
Old Oct 19, 2008 | 02:26 AM
Alaska Hwy 1Le's Avatar
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
91' 5 speed LB9. Been in storage for 5 years. (Dry heated garage). Anyways car runs great except once in a while at W.O.T when motor is around 4000rpm, it just sits at that speed with no acceleration doesn't miss stays smooth but just hovers at 4000 as if an invisible man was holding the car back at constant speed. It only happens about half the time and only in 3rd to 5th gears. I hooked a Genisys scanner to it and recorded it happening. The only thing that popped out was EGR stays at 0% regardless of gear, throttle,rpm. I also recorded it when it pulled strong to 5100 but the EGR was still 0% all the way thru on playback. It also says "lean" when played back regardless if it pulls good or does the 38-4200stallthing. The only other thing scanner revealed was oil temp sensor is buggered cuz it always reads -40c. Would the screwed EGR valve cause a lean cond and the intermittant no accelleration deal? Everything else was within normal parameters on the scanner. No check engine light ever, new fuel filter. Maybe the fuel pump is dying? Can any of you gurus help?
Cleotiz
Jan 6, 2018 08:56 PM
maroe624
Apr 16, 2017 08:29 AM
sreZ28
Aug 14, 2015 07:48 PM
novaderrik
Aug 10, 2015 12:44 PM
gwade12
Aug 8, 2015 08:17 AM
