EGR won't fit!!!???
Old Oct 18, 2008 | 12:43 PM
bigbird89's Avatar
Car: 86 Firebird
EGR won't fit!!!???
I replaced my stock intake/carb with Edelbrock units, now the EGR won't fit, it interferes with the carb on the pass. side. Does anyone have experience with this? Is there a different EGR that will work? Any help is much appreciated!
Old Oct 18, 2008 | 03:03 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: EGR won't fit!!!???
just get a EGR block off plate and slap that on there.
Old Oct 18, 2008 | 04:36 PM
bigbird89's Avatar
Car: 86 Firebird
Is that the only solution? Can I find one of those at Summit?
It seems strange to me that Edelbrock would design an EGR compatible manifold that interferes with its own carb. But then, it's a strange world...
Old Oct 18, 2008 | 07:40 PM
Damon's Avatar
I would call and ask them. I think they figured anyone still wanting to use the EGR valve would be using the stock QJet, since any other carb would not be technically emissions legal, even with a functional EGR valve.
Old Oct 18, 2008 | 08:47 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Would this EGR Spacer work?
Old Oct 18, 2008 | 09:54 PM
bigbird89's Avatar
Car: 86 Firebird
That spacer would work perfectly. Of course, the spacer is $50 on clearance, and the block-off plate is 12.95.
Thanks for the help guys, now at least I know my options!
Old Oct 19, 2008 | 09:05 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I have the Edelbrock EGR adaptor, if you want it you can have it really cheap. If you need to go through emissions testing or visual checks, blocking off the EGR is not an okay solution.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
mdtoren
Aug 16, 2015 05:45 PM
slade5612
Aug 11, 2015 07:19 PM
