Large journel rod bearings....
Old Oct 19, 2008 | 07:05 PM
Jammin'Trey's Avatar
Hey guys Im replacing the lower rod bearings, the one in my rebuilt 350 have these numbers on them...
FM
2555CP
UC
010U.S.
I need to know what bearings I should replace them with...?
I didnt rebuild the motor previous to now so I have no idea what to get, or even what brand?
Old Oct 19, 2008 | 07:13 PM
Re: Large journel rod bearings....
Do i need to plasiguage them?
Old Oct 19, 2008 | 07:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those are Federal Mogul 2555CP, .010" undersized. If your crank journals measure ok you can reuse the same thing.
Old Oct 19, 2008 | 07:28 PM
Thanks, how can I check?
Where can I buy a new set?
Old Oct 19, 2008 | 07:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
With a micrometer.
Old Oct 19, 2008 | 07:31 PM
Like these//// http://www.jegs.com/i/Sealed+Power/8...CH-10/10002/-1
Old Oct 19, 2008 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.jegs.com/i/Sealed+Power/8...CP-10/10002/-1
Old Oct 19, 2008 | 07:47 PM
those are spped pro? Anyways I measured the crank and the crank measure 2.0870 2.0870 2.0800 2.0870. What size do I need?
Old Oct 19, 2008 | 07:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That crank needs to be turned.
Old Oct 20, 2008 | 09:39 AM
oops, i meant they were all 2.0870
Old Oct 20, 2008 | 06:54 PM
Ok, what is the tourqe spec for rod bolts
Old Oct 20, 2008 | 07:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Assuming your rods are sized normally, you're going to end up with about .003 of clearance, which is big for the street.
Torque spec depends on what fasteners you're using.
Old Oct 20, 2008 | 07:36 PM
what do you mean for the street? I am not sure what rod studs it has or nuts for that matter. What is the stock tourqe spec? like 50lbs?
Old Oct 21, 2008 | 06:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
street, ie not drag strip.
If you're using it at the strip only, and use straight 40wt oil, then it's ok. That much "cushion" is fine. But you need the thick oil to make up for it.
Not great on the street, with cold starts, many years of desired service, oil pumps that should last a while, etc.
Stock is about 45ftlbs. Oil on the threads. If you use ARP studs (highly recommended) then use their lube and their spec (obvioulsy).
You can get .011" bearings, and your tolerances will be .002". That's much better. Are the journals very good? ie, you've checked them and there's no oval or marks?
Old Oct 22, 2008 | 09:04 AM
yes, they are in very good shape. I was told that I should run kendall
20w-50. I plan on getting a panheater for the winter... but cant plug it in at school so wont drive it much for sure. The motor was built for the strip. freshly .030 over and everything.
mrbird
Oct 20, 2015 03:43 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
